loss of CH, any suggestions ?
Sep 10, 2010
41
New spa running for 2 weeks, my tap water has zero TA and CH adjusted and tested initially and had TA of 130 and CH of 70, 2days later TA came down to 70 and CH was still 70. todays numbers
FC=7.0
PH=8.2
TA=30
CH= 00
Fiberglass , 400 gal, covered
Bob, CH (like CYA) is one of those items that simply doesn't drop on its own. So either there was some water change (not evaporation) or a sight testing error. If your CH is low, it won't take much to throw-off the result. Are you doing the CH test with a 10ml or 25 ml water sample? Also, do you have a speedstir to help?
It would be highly unusual for tap water to have zero TA as that would mean the water would be very acidic. And, as you noted later, the TA of the spa water was testing at 130ppm then 70ppm. Addition of acidic chemicals will lower TA over time. If your makeup water has low TA and you are not using liquid chlorine, you may need to increase alkalinity using baking soda additions. You really don't want your TA falling below 50ppm as that can lead to acidic water conditions and damage to internal components (like your heater).
If your water truly has zero CH (is it coming from a water softener??), then I would add at least 50ppm CH either with calcium chloride additions OR use some cal-hypo to chlorinate the spa with. Adding in some CH helps to minimize foaming of the water.
No speed stir, I use the 25 ml sample, the sample went from pink to clear after 2 drops. I will run the test again tomorrow.
The calcium hardness (CH) test should go from red/violet to baby blue, not clear. Are you certain you are using the correct test chemicals?
I am using the right chemicals 25 ml sample. 20 drops R 10. 5 11L. And 12 to test. I think my problem is testing indoors under artificial light. Tested the other day and it was more like CH was 100. Which makes sense.
My fill water has a CH of 30 and TA of 40
