- Aug 19, 2017
- 128
- Plaster
- Hayward Aqua Rite (T-15)
We're two months into our first swim season with the new pool and the summer heat has definitely arrived in Texas. I have been faithfully keeping up with the TFP methods and have had zero problems. However, now for the second time in a row I'm noticing a fairly significant CYA loss since my last full set of tests. I test FC and pH every 2-3 days, CC at least once a week, and everything else just monthly since I have realized that it has all been stable. I have to add some muriatic acid 2-3 times per week, but that's it.
I tested today (and re-tested just to be sure) and my CYA is at most 60, probably 50 if I'm really strict about not seeing the dot. One month ago at the beginning of May it was 80. At the end of April I had to add more stabilizer because it had dropped down to 60 from 80 at the beginning of April as well. That's two months in a row. I'm sure my margin of error for this test is at least 10ppm, but I assume my testing error is likely at least consistent and that would mean I'm losing 20ppm CYA or more per month. That's 3-4 lbs worth and seems like a crazy high amount to be losing per month. Any ideas what could cause this and how I could reduce it?
Few more details about the state of our pool:
I have been losing about 1 inch of water per week to evaporation and splash out, which I replace with both regular city water and softened / conditioned water at about 50/50. FC has been staying fairly steady around 5. Currently I'm achieving that with my SWG set to 80% running two 4 hour cycles per day (that's a daily FC demand of 2.5ppm if I used the SWG calculator correctly). Temps have been 90+ and sunny and our pool gets full sun through most of the day. I've been using the pool time brand stabilizer granules from Home Depot.
This afternoon's test results:
FC 5.0
CC 0
pH 7.8
TA 80
CH 350
CYA 50
Salt 3100
Temp 92F
CSI 0.13
FC 5.0
CC 0
pH 7.8
TA 80
CH 350
CYA 50
Salt 3100
Temp 92F
CSI 0.13
