Loose concrete/cement floor around pool
calisoldier
110
CA
Jandy Aquapure 1400
There is some loose cement on the ground around the pool. It’s exposing some of the foam spacers. Any recommendations for filling it in?
Post some wider pics of what we are looking at.
Is that your expansion joint?
Yes I believe so.
I also found a void on one side of the skimmer that needs to be filled in (lots of ants coming from there). It would be nice if there was something I could squirt into the skimmer crevice to fill it completely. This is the backside of the skimmer and may be contributing to the exposure of the expansion joint since splash out may be leaking down around the skimmer housing in that particular void.
Attaching pictures.
Yes I believe so.
Attaching pictures.
@ajw22 also, here is a picture of the pool water entering the skimmer. the epoxy I added turned orange already.
Anybody have recommendations on filling the void in the skimmer and fixing the exposed expansion foam? Also, not sure why the epoxy applied a few weeks ago turned shower corrosion, maybe I needed to be a bit more liberal with it.
