Trying to troubleshoot pool leak
Water level dropped 3/4" per day and then stopped at bottom of skimmer. (bucket test confirmed a leak). I don't see an obvious crack, but did try some dye at the front of the skimmer, and thought Maybe there was a leak on the front corners behind the skimmer face plate (though still not sure).
Also notice some tiny rust like spots on my steps, that I thought might be causing a leak, but I was able to remove them with fine sandpaper, so probably not?
Any and all help would be very much appreciated!
Purchased the epoxy repair putty from Amazon, and was going to try that in the corners of the skimmer.....
