My waterfall pump motor seized hard. But I can't find what the HP and rpms are. And when searching for specs on a Pentair 355222S motor, the HP ranges a lot. I would rather not get the same HP single speed motor as the waterfall is so loud. Would love a 2 speed to have a low flow fall option.
Any ideas from the label? And any suggested 2 speed motor options? Guessing variable motor would cost a fortune if they even have one that works with my existing impeller.
UPDATE: I do not want to touch or use the main filtering variable motor pump system that I have. Because then I would need new plumping changes as well as some kind of electronically controlled diverter valve so the waterfall doesn't run at night during my filtering phases.
