OK, I have an existing Pentair Intelli Touch setup from the previous owner of the house I purchased last spring.
I have only a Pool, No Spa and don't plan to add one (at least not to add to this system)
Here is what is installed right now:
Intelli Touch System i+3
3HP Intelliflo Pump
Intellichlor IC40 chlorine generator (Salt pool)
ThermalFlow Heat Pump Model HP900
Polaris cleaner with a 3/4 HP 220/115V (looks like it is wired for 115V as the breaker is just one pole)
Pool Light
Deck lighting (perimeter of the pool along 2 faces of a retaining wall and steps)
Water Fall (activates a valve I think to the main pump lines)
Fountain (does not really work and I never use it)
Pavilion lighting
I want to get this (I think this is what I need)
Pentair 522353 EasyTouch PL4 Automatic Control System Base with ScreenLogic
right now, the Intellichlor and the Intelliflow pumps do not communicate with the Intellitouch.
I want the Pump, Chlorine generator and heat pump to communicate to the new controller.
I want to be able to use my iphone to control the system.
I noticed that my current system has breakers installed in it for:
1) Pump (220V)
2) Polaris Cleaner pump
3) Pool Lights
4) Deck Lighting
5) Pavilion
6) Water Fall
7) Fountain
There is a separate breaker panel on the side that feeds the Intelitouch system This comes from the House breaker panel
It has lots of openings.
Questions
Is what I linked all that I need?
What do I do about the breakers in the existing system?
Do I need anything else?
I would not mind paying more than what I would pay from the vendor in the link if it meant I would get phone and/or email support from a technician.
3HP Intelliflo Pump
Pool Light
Pavilion lighting
1) Pump (220V)
3) Pool Lights
4) Deck Lighting
5) Pavilion
6) Water Fall
7) Fountain
Questions
