I checked my skimmers/weirs all clear. My steps I have not yet put them in the pool, usually wait until SLAM is done. I havent checked behind my light niche and the main drains, I would never be able to get to the deep end to open that up, shallow side I would be able to. So i'm not home during the day for me to be able to keep up with checking every hour or so and topping off to maintain that FC. Should I maintain my FC at 12 now based on my CYA of 30? Seems like my only good fight is durig the evening when I'm home. I stopped adding DE to the filter since I did the deep clean on Sat. I dont know if I should continue with that or just let the filter do its own thing. I usually see the water getting better daily but I have not been seeing that. The one thing i do see is at night with the light one there is way more less particles floating around and the beam looks less cloudy.Is there anything else below the waterline you haven't been able to inspect either because of lack of time or the water still being too cold to enter? It seemed like last week on the 9th you had a big break in water clarity and no more junk blowing back into the pool, so you should be getting close. Loosing 2 ppm overnight in hours of darkness tells us there is something still active in the water. So add that along with the sun exposure and that would explain a large daytime loss of FC.
I would be very curious about any other potential areas in the pool where algae might hide. Anything? (Light niche, steps, drain cover(s), vacuum port, etc?
