Hello, I would be very grateful for any help. Backstory:
- Have intex soft-sided 8500ish gallon pool. Last year I had a bad algae problem that no matter what I did, and how much I shocked, I could not keep in check. By season end I gave up, drained half the water, and covered it up for the winter.
- this year I opened the pool, drained nearly all of the water out, cleaned heavily, killed all the algae (have been able to vacuum most of it up but having tried 3 vacuums none work that well - still pushes it around some into clouds), and filled the pool back up with fresh water
- also installed brand new filter and sand
- used standard pool opening procedure, with stain remover, clarifier, chlorine shock (1 lb) and a bottle of algaecide (all from a kit)
- now, my pool is blue but cloudy and foamy (the latter probably from the algaecide?). I am getting no chlorine reading so I brought water to a store to test:
-- Free Chlorine: 0.7
-- Total Chlorine: 8.47
-- pH: 7.2
-- Cyranuric Acid: 5 (I have never added any and when I used to try to add stabilizer it never seems to work)
Having a lot of Total Cl but no Free CI, I tried to "unlock" the chlorine with non-chlorine shock, and add 4lbs of Potassium Peroxymonosulfate. Filter is running continuously. 24 hours later still no chlorine reading.
Dozens of hours and $100s of dollars later, I still can't use the pool, so I'd greatly appreciate any advice. I could drain the pool, but I literally just filled it up.
Thank you
SS
-- pH: 7.2
Thank you
SS
