Locale support
aeklo
1
Saksvik, Norway
I have troubles entering decimal values in PoolMath. European locale character for decimal is , “comma”. That is also the only character available on the numeric keypad popping up in PoolMath. When entering a decimal value, the app removes the delimiter making e.g. pH 7,6 into 76.
Any plan to fix this bug?
As a workaround until that update is rolled out, you could copy a dot into the clipboard in a different app and then paste it into PoolMath.
Or you can try adding a second (English) keyboard layout.
I love the pool math app but this one point has been frustrating. I always have a text note open to copy and paste the numbers with "dot" as the decimal separator instead of a "comma" as a workaround but it's annoying to keep having to go back and forth between two apps.
It is not related to keyboard it is based on locale so there's not a quick fix to add a different keyboard. It wouldn't be such an issue if you were presented the full keyboard instead of the "numbers" input keyboard as you could just type a dot, but the numbers keyboard doesn't allow the input of a "dot" (see screenshot).
Any news on when the new update will be out (iOS)?
