I have been having trouble recently with poor suction.
Symptoms:
If I backwash, the flow is powerful and this seems to get the pool cleaner moving nicely. However, the cleaner stops again after about 15-30 minutes.
Any assistance or advice will be much appreciated. Thanks in advance
Symptoms:
- low suction. Not enough to drive pool cleaner (I have a Zodiac MX6 In-Ground Suction Side Pool Cleaner)
- Triton 2 sand filter not pressurizing. Pressure gauge less than 5 psi
- No apparent air in the strainer housing
- replaced all O-rings/seals on the pump and housing
- replaced the "Push-Pull" backwash valve for a side mount multiport valve
- used a hose and back washed the suction side pipes to make sure there was no blockage
- replaced the pool vacuum hose
- also replaced the tank pressure gauge
- replaced the pump impeller
- emptied old sand and cleaned inside of filter tank and replaced with filter balls
