Hey all, I have 23k in ground chlorine pool and just recently programmed my solar to open with the filters running. I'm on Aqualink RS8 controller and Intelliflo VSP 3HP pump. My solar hadn't been working and realized the JVA wasn't assigned so I assigned it in the Aqualink and enabled the aux and now it's working as expected: when my pump turns on for it's scheduled program, the solar JVA opens and water is going to the panels. All should be well.
I noticed however that when this happens my return flow in the pool is very low, I can't even see the surface moving at all. I stick my hand in front of the jets and I can feel a faint flow of warm water. My PSI on my filter is the same, so I think what is happening is the pump is running at the same speed but now since the water has to get pushed up onto my roof and back down, the pressure coming back to the returns in pool is much lower.
Should I program my pump to run faster? I don't know what RPM it's on since it's controlled by AUX input and I can't see the RPM, but just going by sound/pressure alone i'd say it's running on like 40% speed. I would ideally love it to run the pump faster during the hottest part of the day (to do the bulk warming of the pool) and then slower (to maintain) but I don't know how to program a VSP using the Aqualink. Here's some pictures of my gear:
