OK, so this weekend I tried Mark's sugggestion, to make a homemade chlorine feeder.
It did suck in water, but at too high a rate. I had a bunch of 1/2 gal/hr drippers, nine to be exact, but it still sucked pretty hard. And, because my pool is covered, I don't need much chlorine.
But, the bigger problem was I had a few air leaks in my dripper system. This let air into the pump, and caused the pump to lose prime. The pump had to start up dry. A couple times, it would not even start at all. I had to shut it off, and open up the leave trap. For some reason, that made it work. It took me a little while, and some research here to figure out what was going on, and what was causing it.
I did hot glue things together, to keep the drippers from leaking, but I missed at least one hole.
So, for now, I removed the drippers, and the pump works fine. I will try playing with it some more, when I get some time. I am only out $10 for the drippers, an on off valve and an adaptor, so it does not pan out I won't cry
over it.
Randy
