Dealing with CYA 70 even after 1/2 drain. Using liquid chlorine for about a week. 20,000 gallon pool. Using about 1/2 a gallon of 10% a day ($1.80 per day) to stay at chlorine 5-7ppm. Pool looks great. Active sun and TX heat.
I wonder if calcium hypochlorite is a better and cheaper long term solution and just use a flocculant to reduce the calcium when it blasts eventually out of the normal range?
