- Jul 4, 2020
- 509
- Vinyl
- Pentair Intellichlor IC-40
We are in our third season with our pool, and I recently noticed some wrinkles forming on one side of the pool where the skimmers are located (see photo). They are "squishy" when you push on them. We do have a high water table in the area where the pool is located, but I have a well point that collects water from a french drain in the deep end as well as from the gravel around the walls and pumps it to the woods. I double-checked that, and it is holding the level below the bottom of the walls. Any ideas on what could be causing these bubbles? Is it possible that water is entering behind the liner at the skimmers and I just need to tighten the screws on the skimmer plate? Anything else I can try to diagnose? Will they go away on their own? Any help is sure appreciated! -Wes
