Hi, I have a 24' above ground pool. I uncovered it yesterday and started raising the water level. It was drained to just below the skimmer last season. I left the hose running for several hours and came back to this. The liner pulled out from the wall of the pool. I did some research, and I believe this is called a V-bead liner. I heated it up with a heat gun, and was able to stretch it fairly easily, so I think this can be fixed? My problem is the stabilizer bars/rails. I'm trying to remove the one from the affected section so I can fold the liner over the top again. The rails don't interlock with one another, but they appear to be locked into the top plates on the uprights. How can I remove just this one rail without removing all of them? If I pull off the adjacent rails, the liner will pull out of those sections too.
Other concerns: Is there any reason why this happened? Should I expect it to happen again? The liner is about 10 years old. There was also some water in-between the liner and the wall. I sucked it out with the wet/dry vac, but it seems to slowly come back. There does not appear to be any water leaking out of the pool.
Please pardon any incorrect terminology. I'm still learning.
-Chris
-Chris
