Ever since I started with TFP, there has never been a spot of algae and always crystal clear water. In the beginning (right away), I have kept my FC within range. The first few years, my CYA was around 40-50 and now I keep around 30 so the FC can be kept lower. In addition, I really do not brush the walls and only vacuum the floor (manually) as the circulation system is excellent (2 main drains, 2 skimmers and 8 returns).
Each morning, I pour the 32 oz. to 64 oz. in front of a return and the water mixes for at least 2 hours. Then the pump turns on in the afternoon for another 8 hours, during hot weather. I can probably get away with less time and the first few years, I was at 12 hours per day.
Question: Is this sufficient enough for the water to mix with the bleach or should I be running it longer?
In the pictures below, you will find the difference in the fading after a few years. I intend to update yearly in the same spots with the same sample (of course hidden away from the sun). As you can see there is some fading. At this point, I am curious to know if anyone else has taken pictures over time and what there experiences have been. I know there are some liners that have better success, but my liner is a medium blue color (which from one of Chem-Geek's post), will be the type of liner that can fade faster.
Question: Has anyone had better success, and if so, what brand of liners, in addition to colors have you used? This would be a great reference for the future.
The fading is even across the board, that is under water. Above the water line, there is minimal fading (possibly because of the dark color), except the light blue above the pattern which is tucked in to the frame of the pool, under the concrete. It is also hard to tell above the water line as the border is real dark blue (as you can see in the pictures).
