Based on what I can see, yes. To blow out your skimmers, you would put your blower on that, set your multiport to closed, and do each line at a time by closing one of the two valves. I like to blow air from the skimmer out to the pipe or pump with the lid off. This isn't always possible, but it eliminates the need to pump/bail out the skimmer basin
To blow our your returns, you will want to close both of the skimmer valves, set your multiport to recirculate, and then watch as water comes out of the returns. The shortest section will purge first and start to blow air. Plug this and the next section will start to purge. Repeat until none are left. Then you'll want to purge the line connected to the booster pump.
I normally repeat the process on each line again to get a little more water. I haven't had good luck with my shop vac (4.5hp) and I find that I get more water out with an air compressor set to around 20-30 psi.
Lastly, you'll want to remove the drain plugs on your heater, pump, and filter to let them drain. I would recommend storing what equipment you can inside.
