New pool owner here and having various issues. After having my pool opened for the season, I'm getting the following Jandy AquaPure error codes, 172, 182, 185, 186, and I read it could be a problem with my tri-sensor. While poking around, I noticed that none of the lights on my sensor indicator module are on.
I'm going to open the box to see if there is a loose connection to the power cord. While I'm hopeful that might solve the above issues, I won't hold my breath. If that doesn't work, should I be looking to replace the tri-sensor or is there any troubleshooting I should try first?
As well, my pool temp is hovering just below 50. Could that be an issue? I saw someone mention that before, but wasn't sure if I misunderstood the context.
Thanks for any help possible.
