Light dusting at the bottom, is this algae?
May 19, 2018
11
weston, FL
A couple weeks back I SLAMMed my pool that had turned green. I got the water to a nice blue (Thanks TFP folks!)
But now even with scheduled brushing and vacuuming I still have a light dusting at the bottom of my pool. Water still looks clear but worried I didnt finish the job the first time. Thoughts?
This afternoons test results
FC 3 ( using about 50-60 oz daily of 10% to keep the FC right with CYA)
CC 0.5
PH 7.7
TA 150
CH 280
CYA 50
CC 0.5
PH 7.7
TA 150
CH 280
CYA 50
Pool School - Chlorine / CYA Chart
CYA of 50 requires a minimum FC of 4 and a target of 6-8.
Your CC dont show a problem brewing. You should up your FC and you might want to do an OCLT.
I think a bit of debris in the bottom of an outdoor pool is normal.
