- Apr 10, 2018
- 6,323
- Plaster
- CircuPool RJ-45 Plus
Your timer is missing the trippers. They're probably in or around the box.So I can use that yellow wheel timer? That is great. I actually have no idea how to use it, but it’s looks like it should be easy to figure out.
Go to Pool Math "Effect of Adding". Select SWG. For "24 Hour SWG Output", select the SWG model using the search icon. You can play around with the boxes below. Here's an example using the IC40 output of 1.4 lbs per day:So with the Ichlor 30 or the ic40, how long would I need to run it? Do I need to run the pump faster so the SWG will turn on?
