I've been a pool owner for several years, but recently upgraded to a Jandy iAqualink with a variable speed pump. I programmed the daily operation to use a specific speed, but suspect I'm doing it wrong. My questions:
1. When I backwash the filter, how do I tell the pump to operate at a higher speed? I tried pressing the Service->Pump On via the control box, but the pump operated at the default low speed
2. Should the variable speed pump be running at different speeds throughout the day? I live in Dallas TX, and would love some advice on an effective schedule to program.
David
This is what I did to adjust different setting for different applications:
1. Log in to the iaqualink site/app (select "WEB" if using phone app)
2. Select MENU/SYSTEM SETUP/VSP SETUP (once here, you should see your pump on line 1 - unless you have more than one installed)
3. Select SPEED SETUP
4. Select NEXT (your pump on line 1 should already be selected, and if not select the one you are changing)
5. You'll see a list that you can edit (up to 8 on mine)
a. Select one that you'd like to change, type in the RPM you want, and rename (using presets or renaming)
b. Save
6. Select SYSTEM SETUP/ONE TOUCH SETUP
7. Select SET DEVICES
8. Click on a button you're not using
a. Select VSP1 SPD AD
b. Select the RPM you just created in the previous steps (you will find it under the name you saved or created - maybe BACKWASH?)
9. From the main page on the website/app, you should now see it as one of your quick select buttons
I don't use the CLEANER one as suggested in another post because that button will also turn on the booster pump for my Polaris. Hope this helps, and have fun with the new VSP. Hope you find a good RPM for your pool/equipment to properly filter the pool and turn it over properly and use all the equipment that you have. As mentioned, read the owners manual or look online/call to see what the minimum flow rates are for your equipment to operate properly.
