It was on pavers before we filled it but worried about the pavers punching holes in the liner.Look at your water....the water is level. The pool is not. The only way to fix this is to make the pool level, it's leaning pretty bad, I would not consider this safe the way it is.
Are the legs on pavers?
It’s edging that we used prior with our 15 foot pool.What is that track around the bottom?
Thank you for the welcome and advice. Probably a long shot but there is anything we could purchase as extra support? I saw someone used a wood board and created a support system that wayWelcome to TFP! Honestly, this one worries me. Once you get the kids and everyone in there making waves, the water will ram-up against that side with force and whoosh! Actually looks like you might have 3-4 legs that require plumb. At first I looked quickly and thought it was just a matter of the leg base's that needed to come out, but that's not it. Looking closer I see the pool is out of level quite a bit which is why the bottom looks round but the top rail is pushing out. It's just too much out of level and I don't see any other way around it other than to drain and re-level. Sorry.
Unfortunately no, not in this case. The water will continue to exert an outward force against the top rail and nothing can resolve that except leveling the pool in its entirety.Probably a long shot but there is anything we could purchase as extra support? I saw someone used a wood board and created a support system that way
Ok going to drain tonight. Any recommendations as to what I should put under those three legs? Sorry, I am a newbie hereYou need to drain and level properly. You are dealing with thousands of pounds of water... it’s a safety issue.
It’s not a dumb question. It is the same ring, ring is 19ft pool is 18ftI’m sure this is a dumb question, but you aren’t trying to put this pool inside the same ring of edging that was around the other one, are you?
To be honest I think it is more of a centering issue. The back side is about 2 foot away from the border. My husband didn’t straighten out the liner so that is something we have to fix also. Thank you so much for your helpI think that is part of the problem. You either are off center in the ring, or aren’t accounting for the way the legs spread out as the pool fills. So, definitely pull that edging up and start from scratch.
