- Jul 15, 2012
- 604
- Plaster
- Hayward Aqua Rite (T-15)
My spa has been leaking water, about 2 inches/day, masked well by the autofill but obvious by loss of salt, CYN, borates and calcium. I have repaired or replaces leaky pipes, 2-leaky spa Superpumps for spa jets, and a leaky cartridge filter such that teh pool equipment area is now dry. But the spa still leaks. I turned off the autofill and the pump and watched the water fall precipitously the fist 24 hours, then seem to stabilize over next 24 hours at the skimmer line. I do not see any cracks in skimmer however - certainly not at the level where the water is (their may be a small repair made 1.5 inch higher). What would be the next step? Do I look for a leak in the shell at the level of the spa (seems unlikely and difficult to find), do I try to dye-test the skimmer (do I add water first since the water seems to have stopped leaking at this level?), or might I best look at the junction where the skimmer attaches to the spa? Please see photos. Showing skimmer from top and where water enters from spa.
Spa is a 3000 sf standalone "mini-pool" next to pool with its own plumbing. Leak happens with pumps on or off.
