Oh wise ones,
I've had a leak detector guy come out 3 times, and the leaking doesn't stop. On his last visit, he said he removed the fitting that covers the vacuum intake and that he could come back and drain the pool to below that intake, then replace the fitting. Needless to say, I'm not calling this guy again.
I bought some dye to test for leaks. I thought that my leak was in my skimmer, because recently my pool pump broke, so I let the pool go 4 weeks with no pump. The leaking seemed to slow down just below the simmer; and water was still in the skimmer hole, so I was confident that the skimmer plumbing wasn't leaking.
I used some dye around the skimmer, but found no leaks. I used some dye around the removed vacuum fittina and DID see the dye get sucked in. So, here are my questions to you guys.
The fitting that was removed has threads, but the pvc inlet that remains does NOT have threads. I don't know what's going on there!![20180408_175508[1].jpg 20180408_175508[1].jpg](https://www.troublefreepool.com/data/attachments/62/62390-9445036121e4ed87bacf9b42b2452e39.jpg)
![20180506_213019[1].jpg 20180506_213019[1].jpg](https://www.troublefreepool.com/data/attachments/62/62389-3d0d4990f037c5a40f244bcb8271bf76.jpg)
I never used this inlet, because I don't have a "creepy crawler." [Does everybody have a creepy crawler? I just vacuumed manually every week or so.] If you were me, would you just "plug" this hole with something for the time being, then use epoxy around it to stop the leak? If so, what would you plug it up with? I know my pool needs to be resurfaced badly, but I don't have the money to do that right now, and I would like to attempt to do it by myself (or with some help) in the future. If you want to know why I even want to plug this fitting, it's because I want all my suction to take place at the skimmer and the main drain, not here. Also, this pipe might allow some leaves/debris inside, and then clog up that pvc.
Any advice would be greatly appreciated.
Thanks in advance!!!
kc
kc
