- Mar 25, 2019
- 549
- Plaster
- CircuPool RJ-30 Plus
I've got the older style filer in my sig, clamp holding together top and bottom but without a spring on the bolt. When servicing the filter, I used get a leak at the clamp area about 50 percent of the time. Cleaned everything real good, new oring (the one with metal in it), lots of lube, and used a mallet to tap the clamp all around while tightening. Now only leaks maybe 30 percent of the time. Seems to be luck of the draw. Is there a trick to it? I did a search and found similar threads but no definitive solutions.
Also what is the torque recommended? I eyeball it with a 3/4 socket and ratchet and kind of stop when I feel the clamp stop moving, making sure to tap with the mallet at least once. I still feel like I'm overtightening though, and dont want to damage anything. All the paint on the clamp is coming off and looks like it is aluminum from the corrosion. I read its discontinued but even if thats not true it cant be cheap.
