This is a pool in place when I came along. I have met the guy who installed the Hydrotool standard size skimmer and he is not the type to pay attention to details, ergo I am pretty sure he rushed this without researching at all. I Tried tightening the screws and more than one is stripped; probably because not all of the screws are the same meaning likely wrong size. The unit sags enough such that if I try to level it the leak gets considerably worse. He also mounted it 3-4 inches below the top so that limits the water height.
If I remove it completely and start over I assume this is too large of a hole to patch, or since it is near the top (not too much weight?) perhaps this will fly. This is my preference because there is a skimmer at the motor, and get an internal one that moves vertically also. The pool has two 1.25 inch outlets not in use, going to convert to 1.5 and use one as the intake to the motor for the internal skimmer and/or vacuum. Until I convert these the return to pool is going over the top
Perhaps move it up about 2 inches? The patch would be in contact with the pool on 3 sides only. Seems this leaves me with almost the same problem. Lastly I could easily get another and replace the damaged one, but then it is still too low.
Thanks in advance for any ideas/thoughts.
