Leaking multiport
Poolecw
59
NW Ga
The Jandy multiport valve on my filter is leaking from somewhere around the top . Is this a common issue and are there rebuild kits available?
Take off the lid, clean off the O-ring and the areas it makes contact with when installed. Then, put some Magic Lube on the O-ring and reinstall. Should fix your slow leak
Reactions: Poolecw
