Leaking intex hoses and what plunger valves can be used with 12x30?
Jun 5, 2014
244
Brentwood, Ca (Nor-Cal)
Have a 12x30 intex. 1 hose leaks on pump and the “T” adapter. I tried to Remove and silicone grease the o rings but still leaks. What opther option? Clamp can’t go any tighter.
also I’d like to add plunger valves when I clean cartridge filter (believe 1.25” hose) until I get a sand pump. What add ons do I need to convert?
How’s about the time I would be considering hard plumbing. But is the pool in your signature different from the one you are talking about?
Please post a pic of your current set-up. If you want to continue to use hoses, your options are limited until you upgrade your pump.
I can't tell where it's leaking from the pic. Is this the connection you are using:
Have you tried a wrap like this:
Threaded tape wouldn’t work at it’s not a threaded connection, slip/clamp connection. Also disconnected and re-connected but still leaking.
Yeah I agree with @CT-Steven. I’d try some regular screw clamps and see if that fixes things.
My Intex had a couple of joints like that (not as many) and came with regular screw clamps not those plastic clamps.
The only other thing with this fittings which I cannot tell from a picture is if the o-ring is in good shape and seated properly in its groove. It’s not too difficult to slide the o-ring out of position when sliding the hose onto the fitting.
Reactions: Slammed01
Thanks! Can’t wait to ditch filter and be ready for next year for now this will do.
I did unhook and check the orings and all was good, will try real clamps not three ones.
