Hi all,
I'm trying to find a leak in my pool. On Saturday, I noticed it started to get lower pretty quick. I did a bucket test, but it was not needed as I clearly had a leak. I'm currently losing about 1.5" of water a day. So sometime between Friday and Saturday a leak started. The pool was unused all week. We did have an algae bloom last week and I brought the chlorine up to shock level. It cleared up mostly but then I decided to add some DE to my sand filter to get some of the dead algae out. I put in 1/4 cup at a time until the pressure raised about 1 PSI. That took about 1.5 cups. The DE worked great and we did it about 3 times with backwashes each time. One time, the pressure did get a bit high. It got to around 20 PSI. The MAX PSI shown on our gauge is 22 PSI. I'm not sure if that could have contributed to a leak. Although, we were doing that on Wednesday and Thursday, so I wouldn't think it was the cause of the leak.
I did notice that we seem to be losing the same amount of water with the pump running as we do when it is off. We had a leak in our return line last year and we lost about 2" inches a day when the pump was running, but only 1/2" when it was off. The leak was only about 1 foot below the surface (although it had no visible wet spots on the surface). When I dug down, I could see that it would shoot out like a fountain when the pump was on, but only seep out when the pump was off. That helps explain the difference between water loss with the pump on vs off. However, since this time I'm losing the same amount of water regardless of the pump being on or off, I'm wondering if it is not a plumbing issue and instead a liner tear. I've scanned the entire bottom of the pool twice and I didn't notice any tears. Although, I'm not entirely sure I would be able to notice it. If we're losing ~400-500 gallons a day, would that be larger than a pinhole? I'm just trying to figure out what exactly it is that I'm looking for.
I also tried a dye test, but I'm not very good at doing it. I tried it on the return line and it seemed like it might have been pulling in there, but it's pretty difficult for me to tell. I went ahead and plugged it to monitor the level. Early indication seems to show that it is still leaking, but I need more time for better accuracy. I used this type of plug.
Next I will try to plug the skimmer, but I will not be able to plug the main drain.
A couple quick questions.
- Would the fact that we are losing the same amount of water, regardless of whether the pump is on or off, indicate that it isn't a pressure side issue? Last year when we had a pressure side leak, we lost much more water when the pump was on.
- What size tear would I be looking for in the liner if we are losing 1.5" a day (15x30 oval, 12k gallons). I think it comes out to roughly 400 gallons a day that we are losing.
