It should unscrew pretty easily.
The brass is stronger.
You can't fix it without removing the part.
You probably need to cut off the end of the tube with the barb stuck inside.
You can replace the whole tube if necessary.
The threads need Teflon tape and/or sealant.
The tubing just connects the pressure switch to the plumbing.
