Hello,
I have a 7 year old pool with a raised spa. A leak has developed where the spillway stone is connected to the rest of the spa. When the spa is turned off, the outside of the spa facing the pool is wet and I have determined water is seeping along the sides and bottom of the spillway stone. The water level in the spa drops to the bottom of the spillway stone, then stops dropping.
My question is, what type of material should I use to stop the water from seeping? It does not seem like the entire stone needs to be removed then re-set. Would clearly silicone be sufficient?
Pictures are attached and thank you in advance for any assistance.
Mike
Mike
