I replaced the motor on my pump and now I'm reinstalling. I successfully connected one of the two leads, but I was having difficulty seating the other lead under the screw that tightens down to hold it in place, so I removed the screw completely to make it easier to position the lead wire under the screw. Perhaps this was a mistake, because now the screw will not tighten. It just keeps turning. The terminal has a male spade connector, but I'm assuming I would need to solder the lead wire to the female connector (which I cannot readily do) if I take that route. Am a missing a simpler solution?
Warmest February on record (I'm guessing) lead to a green pool, so I need to get pump running ASAP. :-(
