Hi All,
Great community you all have here and an absolute wealth of knowledge! Looking forward to becoming an active contributor.
Question - I am just now installing a 14K gallon (18'x33') AGP in the balmy state of Minnesota. Fundamentally my question is do I install the pool in all regards, fill, get water inline with parameters then winterize things right away -or- something different? Reason for something different I'm guessing is why put the liner and the rest of the setup through one more winter than necessary to preserve additional life out of the liner and associated equipment.
Options I've thought of:
1. Get everything setup, filter and the rest, complete fill, then do a normal winterization (I'm assuming I'd physically move the pump and filter into shed/garage for the winter)
2. Fill pool to below the skimmer box, don't hook up filtration equipment, mix the water with small internal pump getting chemistry right and winterize the pool. Liner stretches as should, walls supported with no worries of having water in skimmer box or equipment.
3. Don't install the pool yet (I have the lower frame 90% in place and level), e.g. don't install the wall/liner etc. Rational here is I'm assuming the leaving the pool up empty is the worst possible idea (walls unsupported/liner exposed to elements etc.). The pool is installed on a mostly clay soil which has a realitivly high water content (house lot backups to wetland) so frost heave is a thing. Guessing frost heave happens regardless if pool is filled or not just image things will shift to some degree over the seasons until next summer.
Additionally, I'm a little worried installing the liner in ~ 50 degree weather (not a malleable as normal) but I could be totally overthinking that. I was going to leave the liner in the house to have it 'warm' before starting to install it should I go with option 1 or 2.
Marty
Marty
