Larger cya viewing tube, how much reagent?
MiguelACA
261
Houston
The cya viewing tube that came with my Leslie's/Taylor kit was crushed. I ordered a replacement but didn't realize I ordered a slightly larger one! How do I use that one? How much water and how much cya reagent?
Equal amounts pool water and reagent. You need enough to fill the test vial you have to the lowest marked level (typically 30 ppm for non-TFP test kits)
You can experiment with it, but I use 14.6 ml of each and it fills the view tube almost to the top.
I use 14.6 because it's marked on the sample vial and I have two of the 9198 vials. I fill one to 14.6 with water and one to 14.6 with R0013 and then mix the two in one vial on the speed stir.
