SO i was thinking of adding a laminar to the pool as i am redoing the existing pool (everything).
i didnt realize till today, but my pool is not in the center of my deck. So if you look at the pic below, you will see its kinda pushed to one side. so i am very unsure where the laminars should go and where the filter equipment should go.
here is a quick lay of the land:
1. Filter Equip: as you can see the heater is on one side and the filter on the other. the previous owners had a very interesting setup. they had a separate pump that will pull water directly from the pool send it thru the heater and drop it back, without ever touching the filter. So i plan to move the heater next to the filter and move them straight back, next to the property line.
Any suggestions if i should move to the North East corner or would North all the way to the property line is better ?
2. I was thinking, while i am at it, i will get a LED pool light installed (there is none now, but since i am replacing the liner, it gives an opportunity) and add LED laminars. but now the shape of the pool is giving me some hesitation.
i was wondering if:
a. adding the lights is a good idea
b. for Laminars whats the best option
(i) all 4 next to the north line of the deck ?
(ii) just get three as in location A, B, C on the map
(iii) get 2 on each side B, C, F, G, but since the distance is not equal, i think this is out of question.
(iv) 2 along the length and 2 along the deep end so B, C , D and E.
Any pool designers to the rescue ?
i was wondering if:
