Hello all - looking for some guidance on our first pool build. We will be building our pool alongside our house so trying to manage both projects has been very daunting to say the least and we havent't even broken ground yet
I've attached a pic of the leading build out of our current bids and hoping the keen eyes can help spy anything we may have missed or possibly need to alter.
Here's the rather daunting list we were given (please let me know if i have left something out):
108’ perimeter pool with 595 square feet of space
3.5’ – 6’ depth
Upgraded colored PebbleSheen
Flagstone coping
Tier 1 waterline tile
7’ circle spa
Raised 12”
Includes rolled beam
Blower
6 jets
Open spillway
Dedicated suction for a cleaner and healthier pool
Autofill & Overflow
(4) pumps
Pool
Spa
Grotto slide
Weeping wall & Gushers
(3) LED lights in pool & (1) LED light in spa
6 Function iAqualink cell phone controls
400,000BTU heater
8’ & 5’ bench
Tanning shelf in different color than the pool
Also includes a Texas star logo
Sunken fire pit area
Sunken 18” with stone veneer
Gunite floors topped with same material as rest of the deck
Walls in sunken area are 18” above the floor with stone or tile veneer, capped with same flagstone as border of the pool
Fire pit has a 34.5” fire ring (so very large) w/ gas
Fire pit can have either glass, lava rock, or logs inside
Sump pump & tank to get water out of sunken area when it rains outside
(4) lights in the bench in the fire pit area
(3) bar stools with Pebble sides and tile tops
Guessing on 100’ of runs for gas and electric due to not knowing exact location of meters
Accent rock
893 square feet of deck coating deck with pattern while topping over existing patio with the same material
4” deck drains
(3) gushers
15’ of weeping wall
10 ton artificial grotto slide
(2) built in, manual ignition, fire rings in the waterfall
BioShield UV sanitation system
Polaris pool cleaner
RS-PS6 Pool Spa Combo w/I-Aqualink
Stealth Pump 1.5hp 110 gpm at 40ft.
Cartridge 460 sq.ft. max flow 150 gpm clean 2 times a year
Thanks for looking!
3.5’ – 6’ depth
Flagstone coping
7’ circle spa
Raised 12”
Blower
6 jets
Open spillway
Autofill & Overflow
(4) pumps
Pool
Spa
Grotto slide
400,000BTU heater
8’ & 5’ bench
Accent rock
4” deck drains
(3) gushers
15’ of weeping wall
Thanks for looking!
