I am converting to Salt Water this weekend and many noted that the ladder Anchors will become an issue. I have regular metal anchors in stamped concrete. Replacing will be challenging. Is here some sort of mainnance that can save them?
Hey Craig !!!! Going salt doesn't matter. You'll be 10% of ocean salinity after converting. Your pool is likely already halfway or more than that because almost everything you add to the pool is a salt, or breaks down into salt.
Poor quality materials break down from moisture, either way.
