Hi,
In recent weeks I've had trouble with weak flow from the returns. I took apart the DE filter and hosed all the insides off a few weeks ago. For the last couple years I've been using the wood fiber substitute instead of DE powder, as I didn't like the DE powder building up in the yard when I backwash. I keep the skimmer and the leaf catcher and the basket at the pump cleaned out regularly. The strange thing is if I run the backwash, even for just a few moments, I get real good flow for maybe a day or so (and lower pressure reading on the DE filter) and then it drops off again, with the pressure reading on the DE filter bumping up to close to the level when I'd backwash again. Also, the last couple times I backwashed, I didn't get much dirty water coming out, and we haven't had much weather that would get much dirt or anything in the pool to clog up the DE filter. The last time I backwashed I didn't put any new fiber in and the water flow still drops off after a day or so. I checked the impeller and there was a little bit of stuff there that I cleaned out. I'm at a loss as to what this could be. I may just take apart the DE filter again just to check everything inside again. But I'm puzzled how I get good flow for a day or so and then it drops off again when there really isn't much in the DE filter itself that would be impeding flow, as far as I know. Any advice, ideas, etc. would be much appreciated. Thanks.
