First post, new owner, etc.
I have a Krystal Clear 603 pump for my Intex 15’x33” pool, which I acquired in late May. I was due for a filter change, and once I changed the filter as I always do, the water was flowing, but poorly. I noticed air in the tubes, so I cut off the filter, bled out the air, and turned it back on. That usually works in this situation, but not this time. I can feel water going into the pool, but it’s far weaker than the usual rushing water and bubbles that I get. Nothing is blocking the inlets and I can’t find any leaks. Water is reasonably clean. If anyone of you far more seasoned folks have some ideas, I’d greatly appreciate them. Thank you for this forum!
