- Jul 10, 2012
- 54
- Plaster
- Jandy Aquapure 1400
I've killed two solar covers (bubble covers) in three years.
I purchased a clear solar cover with I think a 7 year warranty from Dohney's in June of 2016. Originally I figured I could keep the cover on all the time. Pull it back a few feet to add chemicals or remove it entirely to swim. During the second winter I had so much debris in the pool I pulled the cover off entirely and kept it on the roller until it was warmer. Unfortunately when I unrolled it in January of 2018, it smelled like hot plastic and more than half of the cover had disintegrated. They sent me a new cover under warranty in March of 2018.
I started worrying that UV or heat was breaking it down so I move the roller into the shade when the cover isn't on. I do remove the cover when I need to do a good cleaning or shock the pool and I typically keep it off until the chlorine levels are back to a reasonable level. Unfortunately the cover is falling apart again. Bubbles are filled with water and I fish out hundreds of plastic bits every time I pull the cover off. Obviously I'm doing something wrong. I'd like to buy a new cover to both keep the pool temp up (night time temps tend to suck the heat out of the pool) and keep evaporation to a minimum. Should I buy something else?
