Kids will want to swim in 4 hours.....HELP please.
Maybe this will help. The CYA (sunscreen for chlorine) has to be adjusted correctly so you know how much chlorine you have to keep in your pool so you dont start growing algae. You want to be around 30 if your going to use bleach. Less if your going to continue to use the pucks because each puck contains CYA. Once the CYA gets too high your chlorine dose will have to be super high just to do the minimum sanitizing of your pool. If you keep allowing your chlorine to go to zero or 1, we will be trying to explain the SLAM process in a day or two. Best way to fight algae is to prevent it.
