Hi,
So I have a new 600 gallon spa. I am really enjoying it but having a very hard time with the chemicals. I keep dumping in chlorine but it keeps disappearing, then I over compensate & its generally a mess
I have an inground pool (40,000 gallons) so I am a little familiar with chemicals but it seems that the larger pool is much easier to maintain.
I am using the liquid pool shock for my pool in my spa (not attached or sharing anything with pool).
I bought the TFP kit from our sponsor & here are my results.
The T100 test (chlorine & PH) both are way above what they should be. The chlorine was so far above yellow it looked orange. The PH was so far above red it looked purple
The larger kit results showed:
FC - 23 drops or 11.5 ppm
CC - 2 drops or 1 ppm?
CH - 4 drops or 200 ppm
TA - 9 drops or 90ppm
CYA - couldnt even get a reading (black dot never disappeared).
Any advice aside from dont dump 40,000 gallons worth of chemicals in a 600 gallon tub?
Rich
Rich
