- May 23, 2015
- 25,763
- Plaster
- Pentair Intellichlor IC-60
Thanks for the help, so its a slow process - not a quick one.
So if I am aiming to go from 0 to 10, then I use .8 oz which is not quite 2 tablespoons of dichlor.
I will add that tonight & see how the FC goes over the next few days, then slowly add more dichlor.
Should I stay out of the tub for a few hours after adding it?
You can hop in the tub as soon as the dichlor is dissolved, provided your FC is not over 10 ppm and your pH is between 7.2 and 8.0.
Joel beat me to it but I would add this bit of caution - it depends on your chlorine tolerance.
Even with 80ppm CYA in my spa, I hate sitting in the hot chlorinated water if the FC is much over 2ppm (in fact, I actually chemically lower my FC prior to getting in when I use my attached spa). Other people seem to tolerate higher FC with no issues at all. So I would follow Joel's recommended levels but with the awareness that you may find the water uncomfortable. If that is the case, then I would wait for the FC to be low before soaking. Some people let their spa's FC get low, soak in the tub and then bump the FC up higher than typically recommended in between soaks. I'd likely be someone that follows that route if I owned a hot tub.
