- Dec 13, 2020
- 909
- Plaster
- Jandy Aquapure 1400
Re the smaller valve causing a current increase, all other things being equal, it normally works the other way. In a broad part of most pumps' performance curves, power needed varies with flow rate. Adding a restriction reduces flow, so current goes down. For example my VSP reports a small fall off in watts being used as the filter gets dirty and flow rate fades a few gpm (I have a gauge). After cleaning, both jump back up.
