I signed back on line today to close out my "greener than grass" SLAM post with some finishing comments, and I hope you don't mind my pirating your post to do so.
1st, my water has sparkled like never before. Due to some early missteps, my slam took longer than expected, but I stayed with it and my wife has been in the pool more this year than the past 5 together. Learnings:
Misstep #1, as mknauss states, check & keep FC at Shock level as OFTEN as possible. I did not see any results on my 20K gallon pool until I achieved 3 or more chlorine dosings per day.
There were no other missteps, stay true to the process: FC at shock level, brush once/day, more if you can. Consistency & Patience are the key. Adding more chlorine for higher FC level does not accelerate the process. Stay patient. Add Cl 3-4 or 5 times per day (aim for 5/day on weekends).
Not so much a misstep, but buy more R0871 & DPD now. Also, make sure you keep enough chlorine around to get you through few days, or you will be stopping by the store a lot.
Good luck! Did I say stay follow the process & stay patient?
