Hi all,
Just received my test kit (sadly not the one you recommend as tried hard but couldn't find a way of getting one in France...) - I went for a photometer kit in which I crush down different type of little tablets and then it gives me a reading of my pool chemistry. DPD1 gives me FC, DPD3 gives me TC, etc...
Here is what I have just read, and it seems a bit strange to me...
I've done the measurement at 7pm just as the pump kicks back in for the whole night (using a SWG and was recommended to run it for the major part at night)
FC = 0.1
TC = 0.1
pH = 7.0
TA = 174
CYA = 84
Salt = 5
Apparently I should not have any CYA as my SWG runs on a REDOX sensor which is supposed to "self control" using the voltage of the water.... I'm very tempted to turn it off as I don't know/think it was worth the extra cash.
As for the pH it seems to really go all over the place... As I have an pH minus machine, it automatically reads the pH and injects small amounts of pH minus to control the pH of the pool.
Sometimes it reads 6.8, sometimes 7.4 (the max setting it will allow) and then back to 6.9, etc... even though I have not had it running at all (not put any pH minus in it). It just seems to jump all over the place.
In terms of pool problems, apart from regular brown dirt in the center of my pool (its an out of ground pool) which I thought many times was mustard algae (but it feels gritty even though it disappears when you brush it), but I'm thinking it may have just been the pollen/dirt in the air as it was really bad two weeks ago and is much better now (less pollen in the air at the moment compared to two weeks ago).
Sorry I'm a newb on this and it seems my chemistry if all over the place, part of me is wondering if my SWG (which is from 2018) really works that well...
How can I reduce the TA ?
I know the CYA is high, but with kids playing in the water, within a few weeks I'm sure I'll be dropping back down into a normal range...
Any help / advice welcome,
Best,
John.
FC = 0.1
TC = 0.1
pH = 7.0
TA = 174
CYA = 84
Salt = 5
Best,
John.
