Need a bit of help here. Had the pool drained for an acid wash and refilled it but balance is now way off. A number of issues:
PH is extremely low to the point that my test kit said I needed 13 drops to get to my target.
FC is basically 0
TA does not even get to the point where the water turns green so I’m assuming that means my TA is 0?
CYA never blocks out the black dot so I’m not sure what number to record. The scale goes to 30.
Calcium Hardness is 40.
With so much to tackle what would be the recommended order to start addressing this? It has been 1 day since the refill. Pool company added liquid chlorine and muriatic acid on startup. I have no idea why they added acid after an acid wash, but we are where we are.
TIA!
FC is basically 0
TIA!
