Sure I will chime in.. I never have completely figured out the Houston area pool builders bias against SWG's. PB's in other areas will install them. Some builders I hear will refuse to warranty a pool if they have to include a SWG! So owners will have a stub installed and install it later after the PB leaves. Anyway, Lets get-ta myth bustin'
A common misconception is a salt pools are magically different from a chlorine pool. They are not. a Salt Pool is the same as a chlorine pool. A pool with a SWGC just creates chlorine from the salt. A lot of "chlorine" pools build up high levels of salt anyway. And there are lots of people that add salt to their pool just cause they like the feel of it and still chlorinate with liquid chlorine..
Will salt corrode your metals, sure, but not at the salinity that SWG pools have.
Ocean Salinity ~34000ppm
Tears salinity ~7000ppm
SWG pool salinty ~3400ppm
If you live along the coast you may see metal corrosion from the salt air, but that is from the ocean not your pool at one tenth the salinity of the ocean. And will it affect your stonework... only if the stone is cheap. It would degrade either way.
Now to the benefits of SWG's...
-they make maintaining your pool's chemistry so easy most people fire their pool person, even before they find this website
-Chlorine is produced in low continuous amounts and it makes the other chemical levels more stable
-The water feels better to swim in since it closer salinity of your body. no stingy eyes.
-The quality of the water seems a lot better too. My daughter has very sensitive skin and can't swim in a non salt pools without breaking out. A TFP pool probably does the same thing.. but I don't know anybody locally with a TFP pool that doesn't have an SWG where I can test that idea on my daughter
(here honey, jump in this strangers pool, we want to see if you break out)
-no hauling jugs to chlorinate.. or paying a pool guy if you don't want to.
-you can go on vacation and let it do its thing.. They are very stable.
Downsides-
-You pay for the chlorine up front.. The break even point for most SWG's seem to be around 5 years, if you base it on the price of liquid chlorine, then its free chlorine after that.. oh, maybe this should be in the benies column
-The only downside I have found is one can get complacent keeping up with testing because it doesn't change that much.
So there ya go... have at it!
