Since we are slow moving this morning I'll post a few pics. The cumulative affect hit me this morning and the snooze button was hit.
Center line string helped keep us square with the world. No reason to be terribly precise other than just making sure we didn't shift later on.
Radius end blocks dug and buried. Oh joy.
Buttress end blocks dug, leveled and buried. Notice they are turned from previous picture where we had dug then. Noticed our error when reviewing instructions later that day and the change was made. This was before we leveled and filled them. Would they have been OK turned 90 deg? Probably. Are they all 100% perfect? No. The end radius are the ones we made sure that were spot on. The buttress end blocks are level (mostly) but most importantly the spot that the end hits is level with the side frame. Using a spot level on the blocks we kept the bubble in the circle of the center but probably not dead center. Especially the last couple done at midnight.
Shade helps!
Frame up. Then did some house keeping and cleared the area around it for ease of work.
Wheelbarrow ramp.
This pile.
Turned to this in 3 hours.
Ta da!!
Time to go put up the walls! Trying to decide on my skimmer location. It's gotta go in an end per instructions. Previous owner had it under the patio which is fine as long as the basket can come out. Protection from UV's and harm under there. Otherwise I plumb it to the far end. The electric and pump pad are at the patio end.
Shade helps!
Wheelbarrow ramp.
This pile.
Ta da!!
