Jumping in New Pebblesheen Pool Before Chlorine
jrm1855
10
DFW, TX
Greetings!
Given that it’s our day off and fairly hot outside, I’m curious if we would hurt anything by going for a swim in our freshly resurfaced Pebblesheen pool. Pebble was installed on Friday, acid washed/fill start on Saturday, and I spend all day on Sunday following the attached start up guide. Based on the start-up guide, chlorine and CYA don’t go into the pool until tomorrow. Readings as of a few moments ago:
TA: 90
pH: 7.2
While it looks inviting, we don’t want to harm anything long term. What does the TFP wisdom have to say on this?
  • 1-PTI-Start-Up-Maintenance-with-Checklist-All-Finishes-1.20.22.pdf
Only issue is damage to the plaster. If you are gentle the water is no big deal. You bathe in it and I assume no one is sick or has open wounds. Might be harsh from a pH standpoint.
